josue Corona 2 Posted July 18 Hello 😄 In vector work is there a way or even a script that turns an object into a existing symbol. For example lets say i have multiple identical object in the design layers. what I do now is converts symbol and then I go and delete the other that are the same but then I have to past the one that I converted to symbol in its place. What I want is just to highlight the others and convert it into the symbol that I already made . Quote Share this post Link to post
JBenghiat 200 Posted July 18 There is already a menu command that does this, under Modify>Convert Quote Share this post Link to post
josue Corona 2 Posted July 18 are you talking about the create symbol? thanks for your reply. Quote Share this post Link to post
JBenghiat 200 Posted July 18 Modify>Convert>Replace with symbol.. You have to make one symbol first, then select the objects you want to replace with symbols, then run the command. Quote Share this post Link to post
josue Corona 2 Posted July 18 thanks for going more in depth with finding the command, but its weird on my side I don't have it and I already went inside my works space. to try to find it. it is not there thou. Quote Share this post Link to post
JBenghiat 200 Posted July 18 @josue Corona, what version and modules of Vectorworks do you have? Possibly, the command is not part of Fundamentals. Quote Share this post Link to post
josue Corona 2 Posted July 18 its Fundementals,spotlight, and rendtrworks.renderworks Quote Share this post Link to post
JBenghiat 200 Posted July 25 I believe you should be able to find the command in the Spotlight workspace but not in Fundamentals. Are you using a localized version? Quote Share this post Link to post
