hhafsteinsson
All viewport´s disapair / empty
Id did something ( no knowing what) so ALL of my viewports are empty/disappeared.
I have try to turn all layers and classes to ON without success.
I can see the viewport frame on the sheet layer.
If I create new viewport on an new sheet it works fine.
If I create new viewport on an old sheet (that did only showed empty viewport) than I can see the new viewport not the old one.
Here is one of all old sheets with empty viewport.
Now with new viewport on same sheet.
Hard to tell from your description.  If you want to post the file or send it to me in a PM I'd be happy to take a look at it.
Did you check the layer and class options of the viewports themselves? Changing document layer and class visibility will have no effect on the contents.
Did you change the origin? If the viewport is cropped, you may now be showing an empty area of the drawing.
Hello Joshua,
Yes I have check that layer and class pf that and they seems correct, (might be my ignorance of not looking in right place)
Here is example of one of the viewport layer properties with empty sheet layer.
image.thumb.png.e7c22ae735d88b4a9627a7a8f499ddd2.png   Also I have attached screenshoot of the viewport list red line is good example of empty sheet layer v/s the green line with new sheet layer that is working just fine, and when I compare them they look just the same.  image.thumb.png.089197080b094393746de90fcc7f2836.png
I would then check the crop / origin. If the VP has a crop, see what happens if you remove it and fit to objects.
Right as usual, Joshua.  He PM's the drawings to me.  The viewports were cropped to an empty space in the drawing.
