Nik
Pull information from a selected object into a PIO on creation
Here's what I'm trying to do:
User selects an object
User then selects the PIO tool and inserts the PIO
PIO uses info from the selected object as a parameter value.
Currently:
I get the handle to the user selected object using LSActLayer or FSActLayer.
Use GetRField to extract the information from the object.
Run GetCustomObjectInfo to get the PIO handle
Write the information to the PIO using SetRField
The problem I'm having is that it appears that a PIO resets(vsoGetEventInfo #3)  itself 3 times before the creation is finished. On the first reset event the handle still points at the user selected object, on the second reset event the handle is empty, on the third reset the handle points to the new PIO
Short of writing the information to a file how do I get the information from a user selected object into a PIO on creation?
Ideally, you would control the exchange of data outside the PIO:
Custom menu command:
Require a selected object. Extract data from the selected object. Ask user to click a point, then insert the PIO and set its fields. RunTempTool can be useful here.
Custom tool:
Click in the drawing for the insertion point. Insert the PIO. Ask the user to select an object. TrackObject can be useful here.
Note, the tool code does not run until after your first click, so doing the above in the revers order would be difficult.
