RussU Posted July 15, 2019 Share Posted July 15, 2019 I'm trying to export a linetype to DWG It came in as a DWG, I've worked on it a little and now want to output, but the lines lose thier text tags on export... VW on the right, Trueview on the left. Any ideas? Quote Link to comment
0 Vectorworks, Inc Employee Nina Ivanova Posted July 15, 2019 Vectorworks, Inc Employee Share Posted July 15, 2019 @RussU, It could be a line type scale issue or, for some reason, create a line type failure on export. Would you, please, send the document you are exporting and the export settings you are using? You can do that privately, if you wish. Thank you, Nina Quote Link to comment
0 RussU Posted July 16, 2019 Author Share Posted July 16, 2019 Thanks, will PM the file over to you shortly. These were the last export settings I tried. I've tried both options for the "Export complex line types as Blocks" option. Thanks for your help Quote Link to comment
0 Vectorworks, Inc Employee Nina Ivanova Posted July 16, 2019 Vectorworks, Inc Employee Share Posted July 16, 2019 Thank you for the files, @RussU! After analyzing the situation we found, that this is a problem with AutoCAD drawing regeneration. Executing REGEN command or some other action inside AutoCAD, which will require drawing to be regenerated, results in line types shown properly there. Thank you, Nina 1 Quote Link to comment
0 RussU Posted July 16, 2019 Author Share Posted July 16, 2019 Thank you. Further to your note, I found that if you are in TrueView you won't have the REGEN command available. A work around for this is to change the view style from 2d, to hidden line or similar, and then back to 2d to force the regen command to happen. This also shows the lines correctly. Thanks again @Nina Ivanova 👍 1 Quote Link to comment
RussU
Any ideas?
4 answers to this question
