Giovanni Posted July 15, 2019 Share Posted July 15, 2019 I've a problem with a simple "Pain Object". I' ve defined the following 5 parameters: -diametro, Number, 13 -spessore, Integer, 1 -m_assi, Boolean, TRUE -m_lb, Boolean, FALSE -m_lf, Boolean, FALSE Something goes wrong with the selection of the boolean parameters into the "Shape palette" (see Video). Selecting one of them change the status of the others. Can someone explain this issue? Thank you. Giovanni Cerretini VW2019 SP4 R1 macOS 10.14.5 Registrazione schermo 2019-07-15 alle 16.37.53.mov Quote Link to comment
Giovanni Posted July 15, 2019 Author Share Posted July 15, 2019 We have tried on VW2019 SP2 R01 and it works fine! Is this a problem of the updated version? Quote Link to comment
twk Posted July 16, 2019 Share Posted July 16, 2019 Any chance of a code snippet you can provide? Quote Link to comment
Giovanni Posted July 16, 2019 Author Share Posted July 16, 2019 Here attache you can find the plug-in object and the python code. Archivio.zip Quote Link to comment
twk Posted July 16, 2019 Share Posted July 16, 2019 Tried in VW2018 SP6 and VW2019 SP3, there are no instances of the error you showed in the video. Quote Link to comment
Giovanni Posted July 16, 2019 Author Share Posted July 16, 2019 We have a problem with SP4 Architect. Quote Link to comment
twk Posted July 16, 2019 Share Posted July 16, 2019 Oh ok, we don't have SP4 version for New Zealand yet. On another note, I'm wondering how the script works even though the vs.PushAttrs and vs.PopAttrs are syntactically incorrect. They should have parenthesis' -> vs.PushAttrs() and vs.PopAttrs() Quote Link to comment
Giovanni Posted July 16, 2019 Author Share Posted July 16, 2019 Thank you Tui, I've made the parentheses correction but the problem is not solved. Quote Link to comment
