A.D.K. Posted July 12, 2019 Share Posted July 12, 2019 Hi all, anyone know how to extract hang position names for data tag purposes? I'd also love to reference universes used on that position, but that might be more of a long shot:) Thanks! Quote Link to comment
markdd Posted July 12, 2019 Share Posted July 12, 2019 It works really well. I don't think the universes will work so well though! Here as an example Hanging Position Data Tag.vwx Quote Link to comment
A.D.K. Posted July 12, 2019 Author Share Posted July 12, 2019 Ooh, thank you. Don't know why I couldn't find hang position in the object function, but there it is. I'd made a custom record for hang positions that had "Position Name" and a "Universe" text field, but now you've shown me where the name field is, it's probably easier to make it a manual entry. It's just for display. Cheers! Quote Link to comment
A.D.K. Posted July 12, 2019 Author Share Posted July 12, 2019 (edited) Ok next question, how do I make the tag have an "object association"? I have used the same field you did, but it says I have no object association. It seems when I copy a default tag, it retains its object association. If I change the layout, or try to create a tag from scratch, I seem to either break or be unable to obtain an object association. Is there some feature that needs to be included in a tag layout to make or keep its ability to pull its fields' info from an object? The association seems to break even if I don't change the text fields or their definitions. Attached is a sample file with what I hope are sensibly named data tags in the resource manager. If anyone has any insight, the vwx help website is being the opposite of helpful. Bad Data Tag.vwx Edited July 12, 2019 by A.D.K. Quote Link to comment
Peter Neufeld Posted August 2, 2019 Share Posted August 2, 2019 Hello, See if this movie explains it. I created a record with one field for the universe, attached that to each Hanging Position and added the numbers, then edited the existing data tag I made and have posted before that dynamically reports name and weight. Here's a movie and the file. Cheers, Peter Universes Hanging positions and weight.vwx Data tags.mp4 Quote Link to comment
