Developer Wiki and Function Reference Links Read more... ×
Nebeor
How do I avoid the wall insertion of my plugin?
I don't want my plugin to interfere with the Vectorworks walls because it isn't a door, neither a window.
so I tried to tweak with some object variables (varCreateCustomObjectDontInsertInWall),
as well the SParametricDef struct that belongs to the plug-in object but without result.
How can I block the wall insertion of my plug-in object?
I'll thank you beforehand for your reply.
In Vectorscript it would be SetObjectVariableBoolean(ObjectHandle, 6709, True). It should be similar in the SDK.
Try:
gSDK->SetObjectProperty(objID, kObjXPropPreventWallInsertion, true);
(Where ObjID ist the MCObjectHandle.)
In _EventSink::OnInitXProperties()
set:
extProps->SetObjectProperty(objectID, kObjXPropPreventWallInsertion, true);
varCreateCustomObjectDontInsertInWall is actually an application preference (var* are prefs and ov* are object variables). To use that, you would implement in the handle complete event of your custom tool — get the current setting, set to true, restore setting. This is equivalent of clicking the option in the mode bar.
set:
Thank you Joshua, this makes completely sense!
