carpalmer Posted May 5, 2005 Share Posted May 5, 2005 Can't get my drawing label to work. Working on an imported (DWG) file and cannot get dwg. label to click. Other tools will work, but not label... any idea of this problem? Thanks Quote Link to comment
Guest Posted May 6, 2005 Share Posted May 6, 2005 When you click on the tool, do you get an error message? Quote Link to comment
carpalmer Posted May 9, 2005 Author Share Posted May 9, 2005 No, Katie, no error message, just cannot get it to even show in broken line, as if the tool doesn't engage... also now having problems with other tools in that nesting (same file)... Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 9, 2005 Vectorworks, Inc Employee Share Posted May 9, 2005 After palcement does it show in the OIP? If not There is probably a symbol, record, class, or object in the imported drawing with the name "Drawing Label". Try it in a blank document. If it shows in the OIP, then it's either very small or very large. Most of those objects are places at 1" printed size, so it the layer scale it too small or too large you won't be able to see the object. Quote Link to comment
