Missing Vectorworks Libraries
Josh S
7 answers to this question
35 minutes ago, zoomer said:
You need to select one of the Files inside instead of the Folder.
Then they should show up in Preview.
Sorry, the picture is misleading and maybe my question. Their should be more folders and many more trees listed.
The only tree's showing are ones I downloaded on another project.
I've tried refreshing also.
It's like the resource browser is not seeing the vectorworks online library? For example, if you right click the file the download option is not  there.
Guest Alex Sagatov
@Josh-gsy Your second post makes me think it is a specific preference. If you go to Tools > Options  > Vectorworks Preferences > Session Tab > Make sure "Enable Online Content" is checked.
Oh, sorry.
At first I was thinking about a wrong content filter.
But saw that it was set to show all resources, already.
But currently (screenshot) you point to the local VW Library on your Disk.
Where most content would sit in ../Defaults/.....
I think the /Objects-.... Folders are all manually downloaded content.
If you close :
Vectorworks Libraries Folder
User Library Folder
(or scroll, or deactivate their Icons on top, ...)
you should be able to see also, at the same Folder Level, Folders like :
Favorites Folder (just a virtual collection)
Subscription Library (VSS Online Library, if you have a VSS contract)
as you have activated their icons.
@ASagatovVW
Oh that sounds promising. I'm home now so  i will try this in the morning. Thank you.
@zoomer
This is the folder tree I have.
and this is what I am hoping to find:
I'll try the "Tools > Options  > Vectorworks Preferences > Session Tab > Make sure "Enable Online Content" option and report back.
thanks,
Josh
That's the one! No idea when or how that got turned off!
Thanks for your help.
atb,
Josh
I have it checked (enable online content), but still cant see lot of libraries listed on vectorworks site under LIBRARIES & OBJECTS AVAILABLE IN THE VECTORWORKS RESOURCE MANAGER
Do someone have any idea?
