Exporting to DWG
Having problems exporting out VW file to AutoCad 2000 DWG using VW 11.5. I am turning off all of the fills and hatches check boxes. I have walls that are cavity walls and they have a stipple hatch, even with the hatch off it still imports them into the DWG file. I re imported the DWG into VW and it shows up and it should not. It has the same problem with a hatch in a symbol as well. This was done on a G4 1.8 GHz, 512 RAm, OS X and Vectorworks 11.5. Any help?
  • 3 weeks later...
As an update to the post above, the export to DWG problem seems to be apparent with only some files, and was introduced with the latest update (i.e. the 40462 update). I have files that consistently crash Vectorworks when completing the export if someone from Nemetschek would like to review them.
Cheers
Ben
  • 4 months later...
