VW_Harry
Export to DWG from VW
Hello professionals~
Here is my current situation,
Design layer 1 : 1 truss and Lighting symbols.
Design layer 2 : duplicated from Design layer 1.
Exported to DWG. only 1 design layer is in 3D.The other desing layer is in 2D.
Did I correct to exported to DWG?
How could I export to DWG for all design layers in 3D at once?
Edited by VW_Harry
Hi @VW_Harry,
I used Default settings on DWG Export and the result is perfect. I'm using Vectorworks 2019 SP4 (build 490894). I'm attaching the result DWG file plus some screenshots. With yours DWG Export options I get perfest result too.(see cad_test_LayersAsLayers.dwg)
Best regards,
Vasko
cad_test.dwg
Export Options:
DWG Result opened in AutoCAD:
Thank you Vasil,
Would you check one more my file? what is it wrong with this file?
I checked as default ...
My Vectorworks also SP4 (490894)
Kind regards,
Harry.
TO_CAD.vwx
Edited by VW_Harry
Hi @VW_Harry,
One general thing when you want to export 3D graphics - have your active layer before export set to Top view, not to Top/Plan view. If you are using Top/Plan view, you will export 2D views for the hybrid objects.
Using just attached TO_CAD.vwx I was able to see the problem with trusses exported as 2D only even I set the active layer to Top view. Seems this is related to the (sometimes) wrongly passed info to the DWG exporter while we create the objects - we will analyze the case in deep. I will let Vasko @Vasil Kitanov know about this.
There is, however, an easy way to avoid this problem - open the document, set the active layer view to Top, then open View menu, uncheck Unified View, then open again View menu and check Unified View. After that export using Default settings and export will be correct (note - you have 2D only graphics in the Venue layer).
Thank you for reporting and hope the workaround will help you until we fix the problem.
Best regards,
Nina
TO_CAD.zip
