Sam Jones
XML file creation error codes
I am trying to write an XML file with the procedure
result := WriteXMLFile(hXML, -1, XMLFilePathName);
Unfortunately, the result is equaling -1028
result = -1028
1. What does -1028 mean?
2. Is there s list of the error codes generated by file creation and specifically XML file creation
TIA
I don't have a list of error codes, but after a few minutes of playing I think it is the -1 path that is the problem.
It appears based on comments on the developer wiki reference list that you can't access the 1 and 12 (Applications folder and User App Data) folders. When I try I get the -1028 error.
Try -15 for now. This is the Settings folder in the User Library:Application Support:Vectorworks:2019:Settings.
It appears to create the file with no problem there.
Actually -2 works just fine.  The problem was a "/" instead of a "\" in the XML element description.  I later ran into a problem with a space in the XML element name.  However, you should know that accessing the User Folder's Plug-ins folder is easily done with the GetFolderPath(-2).  I do it all the time.
