RGyori Posted June 27, 2019 Share Posted June 27, 2019 Can one have a scale bar, or a second one for that matter, that shows metric in the same document that uses feet/inches as the document standard (or vise versa for that matter)? I have a project for which I am using dual dimensions but cannot seem to find a similar function for the scale bar. It appears that the scale bar is designed to reflect the dimension standard that is tied to Document settings > Units that in turn is limited to one standard at a time, which for me is usually feet/inches. Happy to know if I am missing something. Quote Link to comment
Jim Smith Posted June 28, 2019 Share Posted June 28, 2019 @RGyori I've run into the same problem, but the other way round. The work-a-round I found was to open a blank working file with Imperial units (I think in your case you would open a Metric file), create a scale bar, Ungroup the scale bar then save the resulting objects as a symbol then import the symbol into my document. Not elegant, but it works. 2 Quote Link to comment
RGyori Posted June 28, 2019 Author Share Posted June 28, 2019 54 minutes ago, Jim Smith said: @RGyori I've run into the same problem, but the other way round. The work-a-round I found was to open a blank working file with Imperial units (I think in your case you would open a Metric file), create a scale bar, Ungroup the scale bar then save the resulting objects as a symbol then import the symbol into my document. Not elegant, but it works. @Jim Smith Much appreciated. Might have stumbled across the solution in a month or two 🤔😱🤔. Sometimes inelegant is all you've got. Quote Link to comment
