Jordan Posted June 27, 2019 Share Posted June 27, 2019 OK = so I created a custom view from a large-ish model and cropped in on it to create the desired view on the sheet layer. Rendering it as Open GL with Hidden line foreground. Taking 5+ minutes to render. Is this a typical render time for something like this? See attached images - note the cropped viewport and the entire model seen with "edit crop" active (for reference). I assume when I press update render - everything is rendering in the model? Not just what I am seeing in the viewport? Any comments or help appreciated - I'm new to VWX OBV!! Quote Link to comment
