Sally yang
Plant elevation figure (2D symbols) are not showing
Hi all,
I have downloaded some 2D plant elevation figures (dwg format), and I make individual one as symbol and exported. I want to use them in my elevation drawing. However, even though all the figures are showing properly in resource management, when I place them in my elevation drawing there's nothing showing. I had similar problem with symbols that I created and exported. Are there any way to solve this problem? I have attached an image to show what's like in resource management. The blue dot show where I import the tree figure (but nothing shows up...)
Also, I can only find 2D plants elevation in photorealistic or artistic version. I would like to see if there are some 2D geometric based plant figures that ready to use. Any advice would be helpful! Thanks
Have you checked all your classes are on? maybe the symbol is using class(es) that aren't visible?
@Boh Thank you! I just checked that's the problem indeed! I didn't expect the imported figure is on a new class created on its own and default as not visible...
Glad that worked.  It's often a good idea to import 3rd party symbols into an empty file then adjust classes / attributes before bringing it into you project file. Avoids importing random unwanted stuff and messing up your file.
