vs. AddSurface in this situation??
The Addsurface function only takes in two handles. How would you do a list of handles? As per screenshot below:
where some rectangles are overlapping and some aren't?
using Addsurface in a for loop seems impossible as once the surfaces are added h1, h2 are deleted.
Thoughts anyone?
Got it to work!
# Disclaimer: no responsibility taken for data loss. Code responsibly, save often.
def addsurface_from_list(objs_list:list): # where objs_list is a list of object handles of rectangle/polygon/arc/etc..
    if len(objs_list) > 0:
        fobj = objs_list[0]
        for o in objs_list[1:]:
            add = vs.AddSurface(fobj, o)
            if add not in [0, None]:
                objs_list.remove(o)
                objs_list.append(add)
                break
        addsurface_from_list(objs_list[1:])
Nice work. I thought I had responded last week, but it ended up  sitting as a draft.
You ended up exactly what I was going to recommend. Add 2 then add Repeat add 1 to the result.
You might need to add some error checking. The manual for AddSurface says it only works with overlapping objects. You could get a nil handle for the added object if they don't overlap.
Good Job!
