Sittingducks Posted June 13, 2019 Share Posted June 13, 2019 Hi all, I'm having an issue with clip cube and rendering textures. With the clip cube on it makes edges of solids look rounded or curved faces. One image is Clip Cube off, the other is on. Thats the only change. The texture is colour only, with no reflection/trans/bump. The same thing happens on the ends of nib walls as well Cheers Jason Quote Link to comment
Guest Selin Posted June 14, 2019 Share Posted June 14, 2019 Hi @Sittingducks, clip cube sometimes smoothes surfaces it shouldn't. Can you please DM me an example file or send me an email so we can take a look at it? Quote Link to comment
VectorBits.org Posted July 10, 2019 Share Posted July 10, 2019 Also suffering with this issue. It seems to happen only with boolean solids objects that are clip-cubed in renderworks. Quote Link to comment
Guest Selin Posted July 10, 2019 Share Posted July 10, 2019 16 minutes ago, VectorBits.org said: Also suffering with this issue. It seems to happen only with boolean solids objects that are clip-cubed in renderworks. Yes. This issue will be fixed in the next version. Sorry for the inconvenience. Quote Link to comment
Sittingducks Posted July 10, 2019 Author Share Posted July 10, 2019 Awesome, thanks for that :) Quote Link to comment
Jesse Cogswell Posted February 3, 2021 Share Posted February 3, 2021 (edited) @Selin Did this issue ever get fixed? I've experimented with versions 2019, 2020, and 2021, all with fresh files and I'm still seeing the odd smoothing. Any 3D object that is not an extrude or sweep displays the behavior. The only difference between these two rendered bitmaps is that the one on the right had the Clip Cube engaged. The white cube is an extrude converted into a generic solid, and the glass box on the right is an extrude that has been converted into a shell. Should mention that these bitmaps were produced on a new file in Vectorworks 2021 SP2.1 using Custom Renderworks, all settings medium with ambient occlusion. Edited February 3, 2021 by Jesse Cogswell Quote Link to comment
