At the moment (unless I'm missing something) it's a right palaver if you want to move the contents of a cropped viewport, whilst keeping the viewport in the same place on the sheet.
Typical scenario: you have a zoomed-in detail of a floor/wall junction. A change to the design means the floor changes to a lower level, but the detail of the junction remains the same. Lowering the floor in the model means that the relevant junction now sits outside of the viewport crop (and is not in line with any relevant annotations).
To remedy this you have to:
1) Go into crop edit mode, and move the crop object so that it's in the right place relative to the model view.
2) Exit crop mode. The viewport is now in the wrong place on the sheet.
3) Move the viewport back to its correct place on the sheet.
4) Go into annotation edit mode, and move the annotations back to where they should be relative to the viewport content.
5) Exit annotation mode and hopefully you are now done, unless there are several other viewports that need the same treatment for the same reason.
It would be much simpler if there was an edit mode where the crop object and annotations remain locked to their position relative to the sheet, and you can then move the viewport content around, to bring it back into the crop area, and back into alignment with the annotations, in one go. A one step process.
line-weight
15 answers to this question
