drawing a cupboard
With my limited knowledge of Vectorscript, I tried to write a simple script for the sign of a low and high cupboard in floor plans. The intention is for the low cupboard to have a white filling and the high cupboard to have a dark gray filling. I want to get this by choosing the high or low cupboard in my info pallet. I manage to draw the low cupboard with white filling, but if I choose high cupboard, I only get a line and my cupboard disappears. Could someone help me make this script workable. If it is possible to give a height via the script, this would be a very nice extension for me. Thanks in advance for the help.
[P] kasten.vso
Procedure kast;
VAR
a,v,l:REAL;
teller:REAL;
verdeling:boolean;
tk:string;
BEGIN
a:=pdiepte;
v:=pv;
l:=Plinelength;
verdeling:=pverdeling;
tk:=ptk;
IF tk ='lage kast'THEN BEGIN
rect(0,0,l,a);
FillBack(0);
FillFore(257);
FillPat(1);
PenSize(4);
PenBack(256);
PenFore(257);
PenPatN(2);
DSelectAll;
IF verdeling THEN BEGIN
PenSize(1);PenBack(256);PenFore(257);PenPatN(-499);
teller:=1;
line(0,a);
MoveObjs(v,0,FALSE,FALSE);
REPEAT
Duplicate(v,0);
teller:=teller+1;
UNTIL ((v*teller)>l-v);
end
ELSE IF tk ='hoge kast'THEN BEGIN
rect(0,0,l,a);
FillBack(1238);
FillFore(257);
FillPat(1);
PenSize(4);
PenBack(256);
PenFore(257);
PenPatN(2);
DSelectAll;
teller:=1;
line(0,a);
REPEAT
Duplicate(v,0);
teller:=teller+1;
end
END;
end;
end;
Run (kast);
Edited by tismacfan2
You seem to be displaying fill pattern 1 which is the foreground but changing the background colour.
Try setting it to fill pattern 2 or changing the fill foreground colour.
Also using PushAttrs and PopAttrs for storing and resetting the current attributes is a good habit.
If you extrude your rectangle it will have height and be 3d, after which it can be moved with the move3d procedure.
You could also switch the plane mode to working plane before drawing the rectangle, after which move3d should work on the rectangle. just remember to return it to its previous setting. If you simply want to know the cabinet elevation in plan view, simply create another parameter for displaying in the object info palette.
See if this works for you.
Procedure kast;
VAR
a,v,l:REAL;
teller:REAL;
verdeling:boolean;
tk:string;
BEGIN
a:=pdiepte;
v:=pv;
l:=Plinelength;
tk:=ptk;
rect(0,0,l,a);
FillBack(0);
FillFore(257);
FillPat(2); {change made here}
PenSize(4);
PenBack(256);
PenFore(257);
PenPatN(2);
DSelectAll;
teller:=1;
line(0,a);
REPEAT
Duplicate(v,0);
teller:=teller+1;
end
rect(0,0,l,a);
FillBack(1238); {I did not check to see if this value is in range}
FillFore(257);
PenSize(4);
PenBack(256);
PenFore(257);
PenPatN(2);
DSelectAll;
teller:=1;
line(0,a);
REPEAT
Duplicate(v,0);
teller:=teller+1;
end
END;
end;
end;
Run (kast);
  • 1 month later...
This is an excellent case for the use of Data Visualization in a Viewport.
Create a Record eg. Cupborard Height
Assign Data - High or Low to the various cupboards
And then In the Viewport set how you want them  to display based upon the assigned Data value.
Edited by bcd
