josue Corona
Script needs fixing
I got a scale object Script it works . but what happens is that whenever I execute the script at the end of the command it will tell me that I have not selected any object, but it does scale the object that I have selected .
Procedure ScaleEachObject;
{Scales each selected object in the active layer around the obejct center}
{? 2007, Coviana, Inc - Pat Stanford pat@coviana.com}
{Licensed unde the GNU Lesser General Public License}
Var    H1,H2:Handle;
N1,N2:Integer;
A1:Dynarray[ ] of handle;
R1:Real;
Begin
N1:=Count(Sel);
If N1>0 then
Begin
Allocate A1[1..N1];
N2:=1;
While N2<=N1 do
Begin
A1[N2]:=FSActLayer;
SetDSelect(FSActLayer);
N2:=N2+1;
End;
R1:=RealDialog('Enter the amount to scale each object by','2.0');
N2:=1;
While N2<=N1 do
Begin
SetSelect(A1[N2]);
Scale(R1,R1);
DSelectAll;
N2:=N2+1;
End;
End
else AlrtDialog('At least one object must be selected');
End;
Run(ScaleEachObject);
5 answers to this question
That is my script. I am glad you are using it!
I just copied the script from above and pasted it into a new script. I ran it with both a single object selected and with multiple objects selected. In each case it scaled the selected objects and did not give me any warning.
Are you trying to run it inside a group or symbol? It is only intended to work on object on a design or sheet layer.
What happens when you try and run this on a new file with only a few objects?
Can you send me a file where this happens constantly. I will be happy to try and fix the problem if I can see what the problem is.
oh. I just did it on a single object . it works. but when I did it I was not inside a group or symbol. but I was rotating a group object.
sorry I meant to say scale thats what I am doing . Is there a was to stop warning from group objects . it works just that it says that warning .
