  • 1
Why is a push/pulled NURBS surface a tapered extrude?
Bruce Kieffer
3 answers to this question
I think its as simple as the Tapered Extrude command allows NURBS curves as the source shape and the Extrude command does not. It was probably the easiest way to integrate the Push/Pull command around the existing 3d solid types.
I used to use the Tapered Extrude command with a taper angle of zero a fair amount prior to the additional of the Push/Pull command. It accepts a few more shapes as the starting point (3d polygons for example).
Kevin
This may be related.
I have a 3D polygon (but which is actually a flat surface, created from a 2D poly) at elevation 99850 (Z box reads 99850--see screenshot 1).
I click on the surface and push-pull to create tapered extrude
The base of the solid is unchanged, but now Z box reads 0 (see screenshot 2).
I'm sure I'm missing something simple--is anyone able to tell me what's going on?
Edited by m deasy
clarification
