Hello everybody,
Why is vectorworks 2019 working worse than the 2018.
I tried more than 1 hour to figure out, why my section doen't look like like I want it.
Why lines are missing by my door in VW19 ? ich check all Attributes bei the Walls and the Doors and I didn't find anything.
Could someone helps me ? I don't want lined between two hatchings....
Best regards...
Thomas
Vectorworks 2018
1302914437_Bildschirmfoto2019-06-04um12_18_03.png.e6f1f1c91b6bbaf751d113d361516da9.thumb.png.fdb5646f5c8ea5a5c04fc9e216b5189b.png
Vectorworks 2019
 332888947_Bildschirmfoto2019-06-04um12_13_30.thumb.png.fe9f7b29563bbf1f588728e23e6a0b10.thumb.png.43afb5b04201ff1c5e95c0ca7b28b1b8.png
Guest Wes Gardner
For sections, in the OIP, down near the bottom is the Attributes button for that viewport. I believe, for 2019, there was an option added wit ha check box to "Add Profile Line".  This is what you see in the image below, I have it placed in a class called "2D Profile Line" and can control its lineweight or toggle it off.  This might be what you are seeing in your sections.  It does NOT always work under all conditions.
Wes
