Victor S Posted June 5, 2019 Share Posted June 5, 2019 Hi Guys, sorry for asking so many questions. I need to create a ramp as per attached file, any suggestions? I tried the ramp tool, extrusions etc, but failing at the moment. Thx Ramp.vwx Quote Link to comment
Guest Wes Gardner Posted June 5, 2019 Share Posted June 5, 2019 Hi Victor, I did a quick one with NURBS curves...I'm sure there're other ways but I'm pretty comfortable with NURBS modeling from elsewhere. I just modeled the entire ramp at some percentage...the real one would probably end up being three separate segments???? Or you could play with the rail curves maybe and get the correct percentage of slope and THEN run the LOFT command. Either way Create NURBS curves for the outer "rails" ( I used your polygonal curves - MODIFY > CNVERT > Convert to NURBS Create a NURBS curve for the Profile curve (I just used a straight line but in reality it would have some crown I suspect) From the 3D Modeling ToolSet - LOFT > 2 RAIL Shell command for thickness I originally tried the NURBS roadway but.... The sub-D tool might also help in this... There're some helpful videos, etc. floating around and Vectorworks HELP can point you to some of the modeling tools and their capabilities if you need help with modeling. Wes Ramp NURBS.vwx Quote Link to comment
Victor S Posted June 11, 2019 Author Share Posted June 11, 2019 tahnk you so much Wes Quote Link to comment
