I tried posting this in the Entertainment forum - but its still driving me nuts.
Im trying to use the PAMV command to show LED strip lighting symbols on vertical trusses for both lighting plots and renders/section viewports. The problem Im having is that the most of the LED strip lighting symbols I import rotate in the Model viewport after I run the command. Most of the LED strip symbols I import do this - some dont. All Im wanting to do is have the strips remain vertical on the trusses.
The LED strip will show perfectly in the Definition layer, even in 3D views but will almost always end-up being rotated in the Model layer. The angle of the LED strip changed when you move the DLVP in the model layer.
Ive tried using different truss symbols - but the problem remains. Ive used the PAMV command for conventional lights (profiles & cans) successfully, so Im pretty sure Im not doing anything wrong.
symo
VW file attached.
Plot_and_model_view_issue.vwx
Edited by symoLink to comment
6 answers to this question
