Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Mason2152
Custom Lighting Fixture Not Showing Beams Correctly
I can not figure this out. I have made my own 2D/3D symbol of Mega-Lite's Baby Color because I cannot find one. The problem is I can't get the beam to draw in a cone. Any ideas?1316640339_BabyColorIsoView.thumb.jpg.e2ad0e27ed6efc21845a8ce79d46b8da.jpg1962230747_BabyColorTopView.thumb.jpg.75a5eb24310bcbe1f2b7fb66a4938e09.jpg
Baby Color Test.vwx
@Mason2152 I took a look at your file.  You had no values entered in beam angle 2 and field angle 2.  Vectorworks needs all four values in beam and field angle in order to draw the cone correctly as one value determines vertical spread and the other determines horizontal spread respectively.  I have attached your file again corrected.
Baby Color Test Fixed.vwx
Not a problem.  If you are a member of Service Select you can also request a fixture to be built using the Spotlight Fixture Request Form under the support tab of the Service Select page.
