Mason2152 Posted May 31, 2019 Share Posted May 31, 2019 I can not figure this out. I have made my own 2D/3D symbol of Mega-Lite's Baby Color because I cannot find one. The problem is I can't get the beam to draw in a cone. Any ideas? Baby Color Test.vwx Quote Link to comment
Vectorworks, Inc Employee JustinVH Posted May 31, 2019 Vectorworks, Inc Employee Share Posted May 31, 2019 @Mason2152 I took a look at your file. You had no values entered in beam angle 2 and field angle 2. Vectorworks needs all four values in beam and field angle in order to draw the cone correctly as one value determines vertical spread and the other determines horizontal spread respectively. I have attached your file again corrected. Baby Color Test Fixed.vwx 1 Quote Link to comment
Mason2152 Posted May 31, 2019 Author Share Posted May 31, 2019 Thank you very much. I thought I had done that, just over looked it I guess. Thank you again. Quote Link to comment
Vectorworks, Inc Employee JustinVH Posted May 31, 2019 Vectorworks, Inc Employee Share Posted May 31, 2019 Not a problem. If you are a member of Service Select you can also request a fixture to be built using the Spotlight Fixture Request Form under the support tab of the Service Select page. Quote Link to comment
