Saved view pull down menu does not indicate which saved view is activated.
Wish is for a check mark, radio button, highlighted name or other indicator in the list when a saved view is active. Could also appear as text in the floating data bar, hot corner, OIP, Vis palette, or elsewhere.
A secondary wish is for a different mark to indicate most recently active saved view if view has changed since most recent saved view activation. Eg a grayed radio button or italicized name or?
In general terms wish is for visual notifier in menu or elsewhere if one is changing among similar views or editing the list to establish logical names or establish a new ordering in the list, or presenting by saved view plus subsequent view change via mouse zoom, pan, flyover, etc.
-B
1 answer to this question
Your first wish is probably not possible. A saved view is simply a script that resets the view and visibilities (plus a little bit of other stuff), it is not a "mode' that VW knows it is in or not.
The second wish to show which saved view was activate most recently is probably possible and would be a good addition to the program.
