sandii
Nomad App PDF android issue
Hi,
I created a pdf through the nomad app on my android phone. See below. I could not read the numbers. I then when onto another phone (and i phone this time) and i could see the numbers quite clearly. See attached screenshot.
Can someone help me with why this is occuring?
11 answers to this question
Hi @sandii,
I work with the team who develops the Nomad mobile app. We are able to reproduce the problem you are seeing and we will investigate it. I will post an update when it becomes available.
Thanks,
Iskra Nikolova
  • Like 4
Hi @milezee,
I am sorry to hear that you are having troubles using the AR viewer. Can you please provide more details? What device and OS you are running on? Is Nomad crashing as soon as you enter the viewer, or is it crashing at the point when it is trying to load your model? If it crashes when it is trying to load the model, you can try reducing the size/complexity of the model. I posted some tips on how to do that here:
@inikolova file size is tiny, 2.5mb, using LGV30 android device, it crashes instantly after the viewer has found a surface and I tap the screen to place 🤨
Edited by milezee
extra info
Hi @milezee,
The file size is not the biggest factor when it comes to handling files in AR mode. What matters more is the polygon count. I see that this model has 19706 faces - see the attached screenshot. I realize that this is a Vectorworks symbol from the library, but it has a lot of faceted geometry. Unfortunately, this type of model cannot be handled by the AR viewer engines at the moment. We are actively looking to find a solution for these types of problems in the future.
Best regards,
Iskra Nikolova
@inikolova ok i see, I hope you guys can sort a solution as this makes the AR viewer completely useless for any of the interior scenes we work on
On 5/30/2019 at 5:17 AM, inikolova said:
Hi @sandii,
Thanks,
Iskra Nikolova
Any progress on this issue?
thanks,
Hi @sandii,
I apologize for the delayed response. Our team has taken a look at the issue, but unfortunately, there is no easy fix for this problem. On Android, the library that we are using to handle PDFs is quite old now and has a lot of restrictions. This issue can be fixed if we change the whole procedure that we are using to handle PDF-s. This is on our list of things to do in the future, but I cannot provide an estimate at this time.
Best regards,
Iskra Nikolova
my phone has nomad files I don't even have the right stuff it says to open them why are they on my phone if I can't even open them?
