Phileas Posted May 24, 2019 Share Posted May 24, 2019 I've imported some 3D Objects that are set to be used in a project. However, these objects are made off of 23'000 3D Polys, which makes them impossible to use in a VW file. Is there a way you can recommend me in order to clean the geometry up and import a clean volume into the project? I imported the object into a separate blank file to avoid lags. Quote Link to comment
Vectorworks, Inc Employee jblock Posted May 24, 2019 Vectorworks, Inc Employee Share Posted May 24, 2019 @Phileas You may be able to select the connected 3D polygons and convert them to a Mesh. Once you have a Mesh object, you can use the Simplify Mesh command to clean it up and make it less complex. 3 Quote Link to comment
Phileas Posted May 27, 2019 Author Share Posted May 27, 2019 @jblock ok thanks 🙂 Quote Link to comment
Guest Wes Gardner Posted May 28, 2019 Share Posted May 28, 2019 This doesn't really "clean up" anything, but you can turn it into a hybrid symbol so that you only see 2D linework in top/plan, front, side or rear view (and a "cut view" as well) if you have 2019, but the full 3D object in any other view. Here's a link to Vectorworks HELP.. http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FSymbols%2FCustomizing_Detail_Levels_for_2D_and_3D_Components_of_Symbol.htm&rhsearch=2D graphic 3d&rhhlterm=2D graphic 3d&rhsyns= Quote Link to comment
