Solar Access
You can demonstrate it by running a Solar Animation from the Helidon object.
Place the Heidon with the correct geographical location & rotation with respect to the model.
Be sure you've modeled all the obstructions.
View>Rendering>Open GL Options>Use Shadows
View your model in 3d so you can see the relevant elevation of the apartment
Select the Helidon, in the OIP run Solar Animation
You can outupt a movie file and take clips from this to demonstrate
