Door Window Style ID Tag Change
HWood
How do I change the ID tag on a door or window, without converting to unstyled? Currently all the instances of a particular style of door have the same ID tag! Not helpful. If I go into the settings for a particular instance, the ID tag options are greyed out....If I convert to unstyled, that defeats the object of having pre-prepared styles that can be edited across the project easily e.g. if Client decides to have a different shaped vision panel in the front doors across a series of houses, or we have particular product data to update the style with later in the project. I'm trying to generate a door schedule too.1870460023_Screenshot2019-05-21at13_38_21.thumb.png.97a5ae674a270a9571425e838e1963fc.png993228742_Screenshot2019-05-21at13_38_47.thumb.png.dd62b3451fd74260fcc80839f809ef29.png
Edited by HWood
1 answer to this question
@HWood you should be able to edit the Door Style in the Resource Manager and make the ID Tag section "By Instance". This will allow you to choose whatever Tag options you want for each instance of the Door Style that is placed in the drawing.
