Phileas Posted May 15, 2019 Share Posted May 15, 2019 I have some 3D Polys as source data, from which I want to create a site model. I made sure there are no mistakes like intersecting 3D polys in the geometry, and set everything to be at the real height (roughly 600m above sea level), because I later want all the height indicators to show the real height above the sea level when I'll be making elevation VPs since that's how our office works. However, when I then create a site model from the data, I get this kind of object: I made sure the issue is not layers' height not corresponding to the height of the site model You can check as I will add the file with the base geometry: there are no objects far below the base geometry, so I don't know what might be causing this. Anyone can help me out? this endless tube is just annoying... I'd like to have later height cotations to show 600m above see level, but without have that endless tube object. Is that possible? CRA_EXE_50 Site Model.vwx Quote Link to comment
Vectorworks, Inc Employee Mike Lamb Posted May 15, 2019 Vectorworks, Inc Employee Share Posted May 15, 2019 It looks like there is a bug with stories causing an issue here. As a workaround until its fixed, you can set the story for the terrain layer to none, recreate the site model, then change the change the story back on the terrain layer. Hope this helps... Quote Link to comment
Phileas Posted May 15, 2019 Author Share Posted May 15, 2019 @Mike Lamb didn't work... did you try it out on the file I shared? cause I get nothing but a long tube... Quote Link to comment
Vectorworks, Inc Employee Mike Lamb Posted May 15, 2019 Vectorworks, Inc Employee Share Posted May 15, 2019 Did you delete the site model, and then recreate it from the 3D poly's while the terrain layer's story was set to none? Quote Link to comment
Phileas Posted May 15, 2019 Author Share Posted May 15, 2019 @Mike Lamb yes, and I still get the tube... If it works for you, could you share a VW2018 file with the model like I'd want it to be? I simply can't get it to work for me... Quote Link to comment
Vectorworks, Inc Employee Mike Lamb Posted May 15, 2019 Vectorworks, Inc Employee Share Posted May 15, 2019 Here you go. I also attached a video showing the steps. CRA_EXE_50 Site Model fixed.vwx site model fixed.mp4 2 Quote Link to comment
Phileas Posted May 15, 2019 Author Share Posted May 15, 2019 @Mike Lamb well thank you very much I did exactly what you just did, and still got the tube... weird... Quote Link to comment
Phileas Posted May 15, 2019 Author Share Posted May 15, 2019 @Mike Lamb I've still got some weird stuff going on... I now tried to insert the site model into the file with the building that is supposed to sit on top of it, and look what I got: Any Ideas what is going wrong again? I simply don't get it... I'll attach the file again: EXE CR59.vwx Quote Link to comment
Vectorworks, Inc Employee Mike Lamb Posted May 15, 2019 Vectorworks, Inc Employee Share Posted May 15, 2019 Inserting the site model into a new file is going to cause this to happen again, because the site model effectively gets rebuilt as part of the process. Just make sure whatever design layer you place it into does not have a story assigned to it. After the site model has been inserted, then you can go back in and re-assign a story to the design layer. Hope this helps... 2 Quote Link to comment
Phileas Posted May 16, 2019 Author Share Posted May 16, 2019 @Mike Lamb thanks, I figured it out 🙂 1 Quote Link to comment
Vectorworks, Inc Employee Mike Lamb Posted May 16, 2019 Vectorworks, Inc Employee Share Posted May 16, 2019 @Phileas - Glad you were able to work around it. I did file a bug report for it, but it probably won't be fixed until version 2020. Quote Link to comment
AlanW Posted May 20, 2019 Share Posted May 20, 2019 (edited) @PhileasHi, got it to work ok. Site model design layer has to be set to Zero as the levels work from there. Enter skirt lowest level. See attached. CRA_EXE_50 Site Model v2019 v2018.vwx Edited May 20, 2019 by Alan Woodwell 2 Quote Link to comment
Phileas Posted May 21, 2019 Author Share Posted May 21, 2019 @Alan Woodwell Thank you very much!! Quote Link to comment
Ignacio Gonzalez Posted October 28 Share Posted October 28 Go to "Site Model Settings" and click the "Reset to Min/max of Surface Geometry Quote Link to comment
