Zat1983 Posted May 10, 2019 Share Posted May 10, 2019 When I go to use Spotlight Numbering, there are no fields to select. I started a new file to see if the file was the problem. Not sure what to do. I attached a photo to show what it looks like. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 14, 2019 Vectorworks, Inc Employee Share Posted May 14, 2019 I have not seen this problem before. If you are still having the issue I suggest you contact technical support directly and they should be able to help you resolve the issue. Quote Link to comment
LVLDME Posted January 29, 2020 Share Posted January 29, 2020 any luck? I am having the same issue Quote Link to comment
ScottS Posted January 30, 2020 Share Posted January 30, 2020 I started having this issue in 2020 recently as well. I posted in another thread about not being able to use it for the Event Planning Record to label tables. This used to work, up until a couple of weeks ago. Quote Link to comment
