E Nelligan Posted May 7, 2019 Share Posted May 7, 2019 I've been using lightwright for as long as I've been using VWX so its never come up before. BUT.... Now I need to get VWX to be able to do a "counts" sheet without the help of LW. Essentially a gear list that can be slung to the rental house. I want to make a report that give me a quantity of each of the fixture types in my show so I can make a rental gear list. As it is, I just have a template that has each item listed but I have to manually enter the quantities. Of I can get VWX to count the instruments but then I have to take that number and enter it on the appropriate line. And as for cable, I have no idea how to get a count in. Ideally, I'd like VWX to work like an excell spreadsheet and give me a formula like "lookup the text in the cell to the left, count that quantity, multiply it by 1.15 (for spares), round up to the nearest whole number." Is this even a possibility? Anyone have any basic templates they wouldn't mind demonstrating? Or maybe there's a far better way to achieve this? Quote Link to comment
JBenghiat Posted May 7, 2019 Share Posted May 7, 2019 For cable: Spotlight>Reports>Create Cable Worksheet... The default inventory reports generally match used to inventory totals and use the symbol name, not the instrument type. To make a custom report try Spotlight>Reports>Create report… with the settings below. All worksheets are available in the Resource Manager. Quote Link to comment
Sam Jones Posted May 8, 2019 Share Posted May 8, 2019 To get cable counts, you would need to layout your cable runs with the 4 cable objects and then go to: None of this loads the results into the kind of worksheet you describe, but it may be copied into Excel. Quote Link to comment
E Nelligan Posted May 8, 2019 Author Share Posted May 8, 2019 Thanks gents. Can I ask, how do you make your gearlists? Do you use VWX at all? Or is it just easier to export into something else? Quote Link to comment
JBenghiat Posted May 8, 2019 Share Posted May 8, 2019 The shop order I send out is a Word template. I'll use a combination of VW and LW to do counting, depending on the project and what I'm counting, but I don't want the process to be automated: the shop list contains spares, notes, and detailed specifications that I'm not getting from a pure count. That said, what I usually generate is a bid list from a designer's perspective. I'm not doing any kind of electronic prep work where I may have documented every cable, accessory, and piece of iron. etc. in either VW or LW's database. Quote Link to comment
E Nelligan Posted May 8, 2019 Author Share Posted May 8, 2019 I'd want the base to be automated to give me big broad counts, with other cells able to be directly editable. In the past, I've used excel myself. I just figured there had to be a way in VWX. And to make my spares lists, I tend to put in formulas. For example, in a ballroom with fixed eye bolts in the ceiling, for every motor, I can add Shackle # = (motor number) x 5 Gack flex # = (motor) x 2.25 {rounded to the next whole} Spanset # + (motor) x 0.75 {rounded to the next whole} etc. Quote Link to comment
Sam Jones Posted May 8, 2019 Share Posted May 8, 2019 The worksheet function "COUNT(criteria)" can count things with the same symbol name, same attached record, same value in record field, or a host of other criteria. in the worksheet screenshot below In Cell B4 =COUNT(('HoistVW'.'Type'='2 Ton')) will count all the Hoist plug-in objects that have the value "2 Ton" in the "Hoist Type" field. In Cell B5 =COUNT((R IN ['HoistVW'])) will count all the Hoists. In Cell B6, is your formula for Shackle # which is =B5 *5 You will need to get familiar with the criteria for formulas. This is most easily done by going to the insert criteria menu in the worksheet "Insert" menu This will bring up a dialog: Click on the "Custom..." button, and that will bring up a dialog: You will almost always want to pick Record or Field value from the left hand drop down, but there are occasional times when you will pick other criteria. I don't have the time or expertise to write the book on worksheets of VS criteria and functions, so you will have some research to do. Pat Stanford who prowls all corners of the of this list is the current non-VW employee expert on worksheets. You should get answers to the various questions that come up for you. Have fun. Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted May 9, 2019 Vectorworks, Inc Employee Share Posted May 9, 2019 Does anyone remember LPS pro? I had it before Lightwright and you could email the hire shop your order from within the application. To be honest I think I used that functionality twice. Anyone else use it? Quote Link to comment
Cris with no H Posted May 9, 2019 Share Posted May 9, 2019 Never used LPS Pro, but LW can email your stuff, too. C Quote Link to comment
