3D Pine Trees
In Top Plan View, IP's look like crossed lines, but pop into a 3d View (like with the Flyover Tool) and you will see their 3d(like) presentation.
If you want the best of both worlds, you can use a 2d/3d Hybrid Symbol which contains the Plan View graphic and the 3d IP. For example, try the Symbol called "Plant Basic Evergreen Tree 01". Or, you can create your own (see: http://app-help.vectorworks.net/2019/eng/index.htm#t=VW2019_Guide%2FSymbols%2FCreating_Symbol_Definitions.htm&rhsearch=hybrid symbol&rhhlterm=hybrid symbol&rhsyns= )
JC, here (below) is a  VW's file with the Evergreen Tree. Note 1: see how it behaves like a 2d Object in Top/Plan View and how it changes to a 3d Object in 3d Views (this is a central paradigm in VW's and applies to the entire program); Note 2: if you double click on a Hybrid  Symbol you are given the choice of Edit 2d or Edit 3d. Try it and you will get a better idea of how Hybrid Objects are created. You will also be able to modify many things in the Symbol if desired; Note 3: If/when you create/modify Hybrids, make sure that the 2d alignment is true, center of 2d = center of 3d.
More questions? Post back!
Evergreen.vwx
  • 3 years later...
