symo
Attribute mapping for section styles
Hi All
For my section style, I prefer to use a diagonal hatch that is set in the section style class. The only problem is, when printed - the diagonal lines are too close to each other. Ive tried to use the Attribute Mapping tool in my section viewports - but to no avail. Whats the best way to manually alter the hatch, without having to find another hatch all together?
My first thought is to go to the Resource Manager > Hatches and right click on the applied hatch and select Edit. At the bottom of the Edit menu click on Scale and change the numerical multiplier to s suitable value.
Note that this will change the appearance of all instances of the hatch so if it has been used in places where you don not want the change to show: Duplicate the hatch in the source Manager, give it a unique name and then change the scale. Apply the hatch as desired.    HTH.
