CraigC Posted May 1, 2019 Share Posted May 1, 2019 The VW tutorial I saw on making floor plans showed the viewports as wireframe. However doing so leaves both faces of the wall visible where a door is. If I change the viewport to hidden line, then the doors and windows disappear. How do we make a conventional floor plan where the cut plane is at 4' AFF? Quote Link to comment
Pat Stanford Posted May 1, 2019 Share Posted May 1, 2019 Turn off the Class named "Ceiling-Main" in the viewport and you should get what you want. If you need the swing hidden instead turn off the class named "Sills" 1 Quote Link to comment
