MTRobin
Duplicate Symbol Script
Hi Everyone,
If I have a symbol in my workspace selected I would like to have a script that duplicates that symbol in the resource manager and replaces the selected symbol with the new, duplicated, one. Can someone please help me with this?
Thank you
Maxwell
Here's one I wrote years ago. It doesn't do exactly what you want, but may be it's a start.
{ 20150713 - First written. }
procedure Main { Copy_to_New_Symbol };
var
h1, hL, hG : handle;
N : string;
{••••••• PROGRAM ••••••••}
begin
ClrMessage;
DSelectObj (T <> Symbol);
if (Count (Sel = True) = 1) then
  begin
  h1 := FSActLayer;
  DSelectAll;
  SetSelect (h1);
  Message ('Original Symbol Name : ', GetSymName (h1));
  Duplicate (50, 50);
  hL := LSActLayer;
  SetDSelect (h1);
  SymbolToGroup (hL, 0);
  hG := FSActLayer;
  HUngroup (hG);
  DoMenuTextByName ('Create Symbol', 0);
  DeleteObjs;
  hL := LObject;
  N := GetName (hL);
  SetActSymbol (N);
  SetTool (-209); { or -309 for 3D symbols }
  hL := LSActLayer;
  if (YNDialog ('Do you want to delete the original symbol ?') = True) then
    DelObject (h1);
  end
else
  AlrtDialog ('No Symbol Selected On This Layer !');
ClrMessage;
end;
run (Main);
Thanks for this! It really helped. Here is what I came up with. It duplicates the selected symbol and creates it as a new, unique, one. The same way the "Make Unique" feature works in Sketchup. Do you know how I can bypass the pop up symbol settings prompt and the folder location prompt when creating a new symbol? I'd like to have this script run without any input from the user.
PROCEDURE MakeUnique;
VAR
Selection : HANDLE;
BEGIN
    Selection := FSActLayer;
    Duplicate(0,0);
    DelObject(Selection);
    SymbolToGroup(Selection,0);
    Ungroup;
    DoMenuTextByName('Create Symbol', 0)
END;
Run(MakeUnique);
Thanks
Maxwell
Instead of using DoMenuTextByName(), use BeginSym() and EndSym calls before and after your duplication code, respectively.
Raymond
Raymond
Is there a way to have it leave the instance in place? Really all I need i is the symbol to duplicate with a new unique name and remain in the workspace.
Thanks
Max
Edited by MTRobin
Hi Max,
   There is no need to duplicate a symbol instance to decompose a copy of it. Just decompose the original instance inside BeginSym() and EndSym, giving it a new name. To avoid problems later, it is best to do all your dirty work at the origin. Move symbol to (0, 0) and unrotate before demo and rebuild. To leave an instance in place, place the new symbol at the same XY/Rot as the original symbol when you are done. Here a minimized script to do just that.
VAR
	Selection : HANDLE;
	X, Y, Rot :Real;
BEGIN
	Selection := FSActLayer;	{ get handle to Sym }
	GetSymLoc(Selection, X, Y);	{ get insertion point }
	Rot := hAngle(Selection);	{ get rotation }
	hMove(Selection, -X, -Y);	{ movet to origin }
	hRotate(Selection, 0, 0, -Rot);	{ unrotate }
	BeginSym('Sym New');
		SymbolToGroup(Selection, 0);
		if (GetTypeN(LActLayer) = 11) then Ungroup;
	EndSym;
	Symbol('Sym New', X, Y, Rot);	{ place new symbol on drawing }
	Sysbeep;	{ make noise when done }
END;
Run(MakeUnique);
HTH,
Raymond
This works, but a few things I am noticing.
1. I have objects in 3D and they are not staying in their proper 3D location.
2. When it creates a new symbol with the name 'New Sym' it overwrites the old one instead of adding a '2' to the end of it.
Thanks
Maxwell
Hi Max,
   As I said, it is a "minimized" script. I must leave something for you to do  ;-).  Do you have the Script Reference handy? There are similar calls for 3D Symbol queries, and the naming of new symbols is very subjective. If you don't want the script to rewrite an existing one, then you will have to search for the existence of the new name. If you find it you will have to increment or change yours accordingly then check again, but there are many ways to approach this. Be creative.
   Gotta run now. If you have more questions post again. Heck, @PatStanford hasn't even weighed in on this. If he does you'll get another load of advice to follow.
I'll check back later,
Raymond
OK, since @MullinRJ shamed me into this, I will go back to one of my standard lines:
I understand WHAT you want to the  script to do. What I don't understand is WHY you want to script to do it.
Please explain what you are trying to accomplish and we can often provide a better solution than the WHAT you are asking about. If learning to script is the WHY, then that is great and we will be ready to help. But if it is something else, there may be another way to get what you want (but if you try sometimes, you just may find, you get what you need.) 😉
Hi Pat,
Sketchup has a feature called "Make Unique" where you select a symbol and it duplicates it in place, but as a new unique symbol, replacing the old one. I am trying to do that.
Right now VWX doesn't have a feature like this so the long way is to duplicate the symbol in the Resource Browser, then replace the old symbol with the new symbol. I am just trying to automate that.
Why am I doing this? Often times I have a bunch of symbols in a drawing and I want to make one of them slightly different and then duplicate it.
I work primarily in 3D.
Thanks
Maxwell
We do the same with the script I gave you.
It's a great way of modifying a set of components without affecting the others.
