  • 1
Christiaan
Send to Back/Front command for symbols in walls
I'd love to be able send symbols back and forth relative to other symbols in the wall, in the same way we can with objects using the Modify > Send command.
The reason being is that we often model window sills as separate objects to our windows* and insert them in into the wall at the same place as the window to they're overlapping. The problem is we're usually inserting the sill after the windows because they're a higher level of detail that we don't necessarily need early on in the design process. And this means they obscure the window because they sit in front of it in plan view. So we end up having to drag the window out of the wall, then insert the sill flashing and then re-insert the window object. On some projects we'll also be inserting other ancillary objects such as a railing or lintel. This can be a lot of work; I have 498 windows in the project I'm currently working on.
Maybe it needs a separate command but enabling Modify > Send to do the job may also be sufficient.
* because the Window Object sill is not up to the job.
Edited by Christiaan
0 answers to this question
