Space under door?
@Bruce KiefferI haven't tried this but it's the only thing I can think of is that you could try making a custom leaf with a false gap at the bottom.  Perhaps by adding a 1"+/- tall object without a fill or pen.  Otherwise I don't think it's possible with the typical door parameters because the leaf (custom or otherwise) fills (stretches) in the space allotted for the leaf.
But maybe there is a way.  Anybody else know?
  • 1 year later...
Yes, this is possible. Go in to door settings and select threshold, turn threshold on and set all dimensions to zero (0) then turn on threshold below leaf and set to desired gap thickness. Return to model space to see result.
  • 1 month later...
