Surface could not be created from curve network
Josh Hancock
2 answers to this question
The reason why you can't make the create surface command work is that the nurbs are not co-planar. To get the result I think you are looking for you should try the loft surface tool on the 3rd mode.
  • click the tool
  • select the 3rd mode
  • select the arc curve
  • select the two longest sides
You should get the results in the screen shot.
642886269_Screenshot2019-04-25at11_38_57.thumb.png.7518de98f3cdba7c389ae514cc6ffb07.png
