Acip79 Posted April 23, 2019 Share Posted April 23, 2019 (edited) Hi All, I have problem using space labels. Just need to find out if i am using it the correct way. Refer the attached image. Let say i have 2 spaces and it should reflect different rooms with different finishes for wall, floor & ceiling. The problem is i started with a space the one on the left (input data is paint, paint, paint, paint & plaster), then i made the second space which is the right image (input data is stone, stone, stone, stone & stone). My problem is anything i do to the 1st space label, all the data will automatically changed to follow the 2nd space. This space label is from VWX default library. Thanks, This are the default setting for the space label. Edited April 23, 2019 by Acip79 Quote Link to comment
Acip79 Posted April 23, 2019 Author Share Posted April 23, 2019 Oops... just found out it relates to room finishes tab. sorry...😂 Quote Link to comment
