Vision Orientation issue
Hello,
Why is this happening? how can I rectify it?
So I have GLP X4's I position them correctly in VW when I export to Vision they seem to position themselves randomly as you can see by the attached photos.
I tried turning them by 90 degrees in VW you can again see how Vision positions them.
VW and Vision are both 2019 SP3
Any ideas please?
Thank you
  • 2 weeks later...
2 hours ago, Carl Burnett said:
Wondered if anyone had a solution to this orientation issue. I really need to start programming and this is obviously an issue!
In Vision change the rotation of anything you need, as simple as that. Once it is saved it will show up the proper way each time you load the /v3s file.
