VW2019 - SP3.1? Are there release notes?
  • Administrator
@Kevin McAllister you can ask me 😉...at the end of the release notes for 2019 SP3, you will find 3.1 additional notes HERE
Also, leaving them here:
  • Vectorworks gets stuck if a ForceQuit is received and the user waits 10 minutes before clicking on the alert
  • Design Layer Section Viewports Fail to Show Component Fills in SP4
  • BIM workflow not working anymore because referenced viewports cannot be sectioned anymore
  • Section Viewport trough a referenced Viewport shows no fill components
  • Section Viewport trough a Viewport shows walls without components in SP3/SP4
  • No Detail Level for Slabs in Section Viewport
  • Section Viewports Fail to Show Objects from Referenced Viewports in SP3
  • The first 2 spaces created by the tool have the same number
  • Space label is wrong with styles
  • This update resolves an issue with the floating databar for some plug-ins
  • Add cloud-based project sharing support for Dropbox Business and Box Drive
What exactly does "Add cloud-based project sharing support for Dropbox Business and Box Drive" mean? And how can we use it?  Can we now just store shared projects on Dropbox and Vectorworks will magically work or is there some other setting that needs to be set up or activated?
Edited by cberg
  • Administrator
Even though in the past we have been supporting Project Sharing with different cloud-based solutions, we were lacking support for Dropbox Business and Box Drive that now is included in Vectorworks 2019SP3.1. We are working on a Kbase article to explain this process in detail that will be posted as soon as possible.
