I am making a mechanical design of an object, and I have an instance of it as a 3d symbol in my design layer.
When I do a sheet layer with viewports of the different views and do Dimensions in Viewport Annotations, "Radial Dimensions" is not working.
If I select a circular object the center of the radial dimension measurement ends up in a galaxy far, far away outside the object.
However, if I go back to the design layer and do "Convert to group" and then update the viewport, it works.
Is this a known problem?
Am I using a stupid design method, trying to maka an annotated drawing of a 3d symbol?
The reason want to do it this way is that I am afraid that the 3d symbol which I am sharing between drawings might not be properly updated during the design process, due to my mistakes.
If I take the measurements on the actual symbol, I can be relatively sure it is correct.
If I use a "flattened" copy of it, they might be different.
Bengt Nilsson
Hi all,
BN
0 answers to this question
