Callout Tool Problem
ccw
Hello Everyone,
So I am all of a sudden having a problem with the callout tool. If you look at the screenshot that is attached  you will see one callout that reads “Foam Insulation” and then above that one that reads “2X (PER Plan) @ 16” O.C.” The problem I am having is if I go in and alter the top  one the leader and arrow disappear and it ends up looking like the bottom one. What is causing this and how do I fix it? It does this on all new documents as well now. I don’t know what has changed.
