herbieherb
ExportImageFile does nothing
I am trying to make a script that exports an image object to a specified file path. Everything works well but vs.ExportImageFile(hImage, path) does nothing.
Here is the script:
________________________________________________________
#Get selected bitmaps
crit_ = '(((SEL=TRUE) & (T=BITMAP)))'
out_list = []
def Add_Handle(obj):
    out_list.append(obj)
vs.ForEachObject(Add_Handle,crit_)
#GetFirstImage
hImage = out_list[0]
#Choose path
fileName = vs.PutFile('Choose path:', 'image.bmp')
#Exort Image to path
vs.ExportImageFile(hImage, fileName)
vs.Close(fileName)
And an example file:
export image.vwx
vs.PutFile() is used for text files, but you want to create an image file.
I suggest building your path using vs.GetFolder()
You also will not need to use vs.Close() after making this change.
fileName = vs.GetFolder('Choose path:')[1] + 'image.bmp'
(You need to extract the second output from GetFolder, which is why the [1] is after it.)
Thx a lot. This worked well.
Here is the file with the scripts that export images directly. I had to use two scripts for jpg and png as i couldn't find out the image type.
export image.vwx
Is there a way to find out if an image is a png or a jpg?
Yes. This one liner will show the compression used on a placed image:
vs.Message(vs.GetObjectVariableLongInt(vs.FSActLayer(), 532))   # 1 = JPEG, 2 = PNG
Raymond
30 minutes ago, herbieherb said:
I have extended the script so that rendered viewports can now also be saved directly as images. The script now takes the name of the object as prefix of the file name.
Here is the current script:
export image v2018.vwx
export image v2019.vwx
I've just tried running this in one of my files... but get this error message
1883054349_ScreenShot2019-06-07at13_48_30.thumb.jpg.2a7be8a50c25b864afad891790fc9d30.jpg
That seems to happen whether I try it on a bitmap image, or on a viewport (have tried both Renderworks and OpenGL vports)
Found the issue. Selected objects from other layers interfere with the script somehow. I'll try to fix it.
I've done a few quick tests and this appears to work really well! This seems to satisfy a simple function that people have requested repeatedly from VW for years, so thank you for taking the time to create this!
Question - is it possible for a script like this to be made to work on multiple viewports at once? For example, if I have a grid of 12 renderings and I want to save out the images from all 12 at once?
Yes, that should be possible, but it requires some work. I will take a look at it on occasion. Until then you could integrate the script as a menu command into your VW-UI. Then just shortcut it to use the script faster.
Edited by herbieherb
Amazing, thank you herbieherb! The ability to export multiple viewports, plus the naming improvements are all really fantastic.
By the way, before adding the script to my workspace as a command, I put a pound sign in front of lines 28 and 29, since I want to be able to export out-of-date viewports as well. I know very very little about coding, but this seemed to work 🙂
I've just been using this too - thank you very much @herbieherb
Like @Andy Broomell I'd like to be able to export out-of-date viewports, so I have also disabled lines 28 and 29 (using a £ sign didn't work for me, but just deleting them did)
One comment, if you run the script, but then click 'cancel' instead of 'open' in the dialogue asking you for the file location, the image is not exported (as expected) however a message saying an image has been exported is returned nonetheless.
Use # instead of £
