Pavol D. Posted April 12, 2019 Share Posted April 12, 2019 Anybody having an issue of not fully exporting space label... Here are my export settings exported VP and result. Pavol Quote Link to comment
0 Vectorworks, Inc Employee Nina Ivanova Posted April 12, 2019 Vectorworks, Inc Employee Share Posted April 12, 2019 Would you, please, send the Vectorworks document directly to me? Thanks, Nina Quote Link to comment
0 Pavol D. Posted April 12, 2019 Author Share Posted April 12, 2019 File is 800MB...i will try to reproduce in new one and then I send it you. Thanks for help. Pavol Quote Link to comment
0 Pavol D. Posted April 12, 2019 Author Share Posted April 12, 2019 Ive copied space object with style into a clean new file, created VP of it and exported to dwg and it works fine... Sending copy of the file. space label bug.vwx However in original file those spaces sharing same space style which I created in another file... and there i've noticed something odd: If i create VP of that space object and if 'Show 2D Boundary' is on it will not show space label (only text part)...and when I want to 'edit layout ' of the space style I get this: Maybe that is what is causing issues....? Here is link to original thread: Or do I need to create space style from scratch...? Thanks Nina. Pavol Quote Link to comment
0 Vectorworks, Inc Employee Nina Ivanova Posted April 12, 2019 Vectorworks, Inc Employee Share Posted April 12, 2019 I think, that the export problem in your original file and the problem given here are different issues, but still there might be some relation. @Jim Wilson, do you have any thoughts about the space issue? Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted April 16, 2019 Vectorworks, Inc Employee Share Posted April 16, 2019 On 4/12/2019 at 7:48 AM, drelARCH said: Ive copied space object with style into a clean new file, created VP of it and exported to dwg and it works fine... Sending copy of the file. space label bug.vwx However in original file those spaces sharing same space style which I created in another file... and there i've noticed something odd: If i create VP of that space object and if 'Show 2D Boundary' is on it will not show space label (only text part)...and when I want to 'edit layout ' of the space style I get this: Maybe that is what is causing issues....? Here is link to original thread: Or do I need to create space style from scratch...? Thanks Nina. Pavol You should contact tech@vectorworks.net directly about this and have them take a look and these files, I suspect they can show you how to correct it without having to recreate it. 2 Quote Link to comment
Pavol D.
Pavol
5 answers to this question
