GW Rodriguez
Custom Title Block - Scale Text
Hey folks,
I have a custom Title Block that has a text box for the Sheet Title. Is it possible to have this text scale based on how wide it is? See the two screenshots attached where the first labeled "Speaker Plot" fits just fine, but the second one labeled "Speaker Plot Annotated" is so wide is goes out of the bounds of my Title Block. It would be great if the text could shrink, wrap, or something.
Thanks,
GW
Hello @GW Rodriguez,
If you are using Title Block Border object you could edit its layout, select the text object and make sure "Wrap Text" is clicked in its OIP. Also, you should resize the text to set its maximum width and it will not become wider than that.
Best Regards,
Nikolay Zhelyazkov
