Developer Wiki and Function Reference Links Read more... ×
GRZEGORZ
Connecting N-th element from different lists
Hello!
I have question. How can I connect n-th element from different lists?
The situation looks like this: there are two circles and equal numbers of points on them. I want to connect points of the same index on both curves (the 1st on one curve, and the 1st on the 2nd one, then pair of 2nds points on each curve, then 3rd and so on).
I know that there is a way to do this manually (List Explode node), but how can I do it in more parametric way e.g. if I do not want to specify the exact number of points on curves, or I simply do not know how many of them are needed.
Connecting Nth element.vwx
Hi GRZEGORZ,
you're almost there already. To make the connections between the two circles, you need the Polygon3D node, which takes lists of points. List of points in your case would be point pairs. To get those first ZIP both outputs of the Divide Curve nodes and then CHUNK this big list into lists of two elements (pairs).
Antonio
1543030395_Bildschirmfoto2019-04-10um11_58_32.thumb.png.4b855390a7f3d8adfa44431933fb27fa.png
